cancelar
Mostrando los resultados de
Quiere decir:
Remove ROADS and ADD Mobility category
After 11 years of using Revit, I'm yet to learn how you create objects of this category :cara_con_una_leve_sonrisa: Or maybe it is time you removed it from the VG dialog. I also suggest creating a new category: Mobility, for elevators and objects alike. Or maybe you guys can find a better name for it.
5 Comentarios
samuelsanf
Currently the only way I see to use the Road category is to import CAD in SAT format and select the ROAD category.
I used to export Civil 3D Corridor into SAT to export into Revit (I don't like the Site Designer's road tool, doesn't flow with the terrain).
But realy, this category should be more accessible.
Basam.Yousif
Can you please show me how you do that?
samuelsanf
Here you can see,
For Rhino and ACIS SAT files, the process is the same, you can select from a list the category for the model to insert.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
Here you can see how to Export from AutoCAD to SAT
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
In Revit you can Export to SAT too:sat.png
But importing 3D objects is the only way I know to use the Road category. It isn't  possible to assign this category to a revit component nor families.
samuelsanf
The problem when importing roads this way is that you can't import them with shared coordinates; you must need reference geometry in order to move it to the correct location. Emoticono triste
We really need more integration with Civil 3D. And that could use the Road category.
Basam.Yousif
WOW!!
I did not know this at all, and I wonder if they intended it to be available!
Thanks for showing me this :cara_con_una_leve_sonrisa:
Enviar idea
