Please consider removing the minimum room dimension. Currently rooms cannot be placed in a bounded area where one of the dimensions is less than ~11". Rooms are often used to calculate areas of shafts and chases and in certain project types, these areas are often very thin. We also often want to view simplified plans where shafts (and also above ceiling spaces in sections, but that is probably another topic) are just filled in with a solid poche. I think this could be achieved (in plan at least) if we could place rooms in all of those spaces and apply a Color Scheme to them to just color the shafts and chases solid black, however these thin spaces pose a problem there. Rooms that automatically adjust to fill a bounded space are great and could be much more flexible without an arbitrary minimum size. Alternatively a different object type could be created that behaves dynamically like a room, but doesn't have to answer the existential question about how you could possibly call such a small space a room.
Desired functionality:
- Tagging very small rooms like plumbing chases for asset tracking and locations in a building
- Graphically overriding chases and shafts for clean "usable space" diagrams
- Accurately calculating areas of chases and shafts dynamically as the plans evolve
