Remove Cad Import from project
Is there any method for identify CAD imports files in project and can remove within Revit?
3 Comments
Hi, @nihalmehdi ,
Is this a question or a suggestion for a new improvement to Revit? This may be better served on our forums. I can move this post if you like.
Thank you!
-Kimberly
nihalmehdi
Hi @kimberly_fuhrman-jones ,
It's a suggestion, if Autodesk can do a new improvement in Revit.
Thank You:
Nihal
Thank you, @nihalmehdi ,
Do you mean to be able to remove the CAD links as you are opening a Revit model? For example, opening the Revit model with an option to remove the CAD links?
-Kimberly
