When selecting duct accessories and duct fittings, you can change it's level and elevation with the 'Level' and 'elevation from Level' parameters. When selecting ducts, you use the parameter 'Reference Level' and 'Middle Elevation'. This makes it so you can't select everything and change the elevation, and you can't filter ducts and duct fittings/accessories on levels in schedules.
Is it possible to make these parameters the same?
