La sugerencia automática le ayuda a obtener, de forma rápida, resultados precisos de su búsqueda al sugerirle posibles coincidencias mientras escribe.
Mostrando los resultados de
Mostrar solo
Buscar en lugar de
Quiere decir:
Esta página se tradujo para tu conveniencia mediante un servicio de traducción automática. No es una traducción oficial, y puede contener errores o traducciones imprecisas. Autodesk no garantiza, ni expresa ni implícitamente, la precisión, la confiabilidad ni la exhaustividad de la información traducida por el servicio de traducción automática y no será responsable por los daños o las pérdidas que se produzcan como consecuencia de la confianza depositada en dicho servicio.Traducir
Not sure that this is really needed. You can already either click on any line in the contiguous shape and then press TAB to select all the line segments or you can group the lines for even more powerful way of manipulating the geometry. Grouping is my favourite because it allows you to use the align tool on the shape without moving any of the line segments.
What you really want is polyline support (not just rectangle, but romboids, trapezoids, polygons, etc). Because closed polylines gives you area and perimeter totals. And you can edit them very easy by dragging the blue grips. It's really annoying when you want to edit a slab contour in Revit. Need to do multiple trim/extend commands. It would be really easy to just drag some grips.
@dplumb_BWBR: I didn't know that. Thanks. I was trying to mimic Autocad behaviour: few polylines instead of hundred lines = fewer elements=smaller file=faster editing. I don't know if that actually counts in Revit as it does in Autocad (when strictly referring to lines/polylines).
