Rebar in Legends
Rebar in Legends
The ability to have Rebar in Legend so that you could dimension each rebar required. This might Require Autodesk to change rebar from instances to types as the same rebar shape (with given set of dimensions) will likely be used multiple times in a design.
Question in Revit structure forums: Rebar shape legend - Autodesk Community - Revit Products
Autodesk Customer Advisory Groups
