REBAR IMPROVEMENT - REBAR CRANK AND LAP SPLICE
Dear Developers,
Please consider to provide option to bend the rebar in plan especially at beam column joint and option for Lap splice in Area reinforcement. These are the 2 fundemntal requirements when considering the 3d modeling of the Rebar. But still there  is no straight forwared option in revit for this if my understanding is correct.image.png
7 Comments
peticid
Status changed to: Accepted
johnl5PYL9
When will this function be available? @peticid
Also, we need the option to crank the bar in any direction, eg beam laps where the bar may need to rotate to avoid a clash. possibly something similar to the rotate hook option.
peticid
Hi John,
Rebar splicing, including using cranking, is on our public roadmap.  You can test the current state of our prototype using the Revit Preview version. This is the dedicated forum thread, where you will find the feature summary and you can share your feedback after testing it.
In case you are not a member of the Revit Preview community, you can use this link to enroll.
Kind regards,
Dan Peticila, M.Sc. Str. Eng.
Product Manager | Autodesk Revit
johnl5PYL9
Thanks for your response.
ahmadalrashed20
Community Visitor
Hi @peticid
my manager tested the preview version, but it didn't have cranking 🙄
peticid
Hi Ahmad,
Thank you and your team for testing the Revit Preview release. Please do not share feedback about features which are not commercially available on this standard Revit forum, as this breaks the non-disclosure agreement signed when you joined the Revit Preview community.
We would really appreciate continuing this conversation on the dedicated Revit Preview forum thread: https://feedback.autodesk.com/project/forum/thread.html?cap=cb0fd5af18bb49b791dfa3f5efc47a72&forid={...
Kind regards,
We are pleased to say that this has been implemented in Revit 2026! Thank you for your contribution to improving Revit!
Help | Parametric Rebar Cranking | Autodesk
 -The Factory
