Ramp - Cut in plan
Ramp - Cut in plan
I don't undertand why the problem of cutting ramps in plan haven't been fixed yet! We are tryinf our best to use Revit and we`re hopping Autodesk is doing their best! The Ramp problem is a HUGE problem and is a old problem! Please Autodesk!! What are you waitting for? Deffendig Revit is a hard task with problems like that! I'm dealing with these problem since the 8.1 version! Come on!! We need ramps to be cutted in plans lust like stairs!
5 Comments
andresmontemayor
They are aware of the issue, it's completely dumbfounding they haven't fixed this massively simple issue.
Why would everything cut accordingly but not ramps? They're practically saying we shouldn't use this flawed tool.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/R...
asimasko
Using Revit 2021. Also checked in 2022. Still broken 5 years later. Easy fix is to change the name of the software from Revit (which I understand is an acronym for Revise It) to Wart (Work around it). That would also cover a myriad of other broken or low functioning tools.
b.purssey
Observer
Dear Autodesk – any advances on this stone age problem?
Dear Anyone in fact?
Cheers
Ethan_mok
It's 2025, 8 years since this was posted. I'm using Revit 2025. So many of our projects use ramps in our multistorey carparks. Can we please get properly displayed cut ramps in plan?
20221991
Community Visitor
Más de 9 años de la primera queja y todavía sigue el mismo problema. Revit 2026...
