cancelar
Mostrando los resultados de
Quiere decir:
"split with gap" for pipes and ducts
In Revit, the split command cuts a pipe or duct in two, leaving a fitting between each piece.
If you need to really separate the two endings, you need to break twice and delete what remains between.
There is a button "split with gap", but this button does nothing on pipes or ducts.
See video for example: https://knowledge.autodesk.com/community/screencast/0a216a02-ccb7-40e9-9581-9396182b1ea4
In AutoCAD MEP, splitting a pipe or duct leaves a real gap between each ending which size we can choose.
See example: https://knowledge.autodesk.com/community/screencast/7727df0d-81fb-4aa3-a416-86932626be8f
AutoCAD MEP does it clearly more fluently. Could it be possible that Revit does it as good?
8 Comentarios
pieterdewaal
This is essential for anyone doing ducting or piping runs in Revit... I've always been confused as to why "split with gap" is only designed for walls. It already has a "Joint Gap" parameter that can be preset for ducts and pipes.
Modifying 100's of pipes/dcuts for soffit steps would be a LOT less tedious with this feature :).
El estado se ha cambiado a: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our Revit Public Roadmap. Thanks for the suggestion!
The Factory
El estado se ha cambiado a: Implemented
We are pleased to say that this has been implemented in Revit 2023.1! Thank you for your contribution to improving Revit!
 -The Factory
Dave_Texter
I am using 2023 and this does not appear to be implemented.  Am I missing something?
pieterdewaal
@Dave_Texter The contextual menu allows "Delete Inner Segment". It does leave the split line unions though... which leaves it the same amount steps. I was hoping it would be a single click to split the pipe based on a fixed distance.
Dave_Texter
When I try to use the tool, absolutely nothing happens.  If I click on the tool and then click on a pipe, it exits the command, like nothing has happened.
pieterdewaal
@Dave_Texter Use the "Split Element" command under Modify -> Modify, or use the OOTB shortcut "SL", check the "Delete Inner Segment" and select a duct/pipe to apply.
If this doesn't work, it means your Revit 2023 is not yet updated to 2023.1+.
Dave_Texter
Never noticed that check box.  I guess it's better than nothing.  Thanks!
Enviar idea
