"prioritize" line weights when plotting - heaviest on top
Inserted families will often obscure the line weights of the walls, causing visibility issues. There should be a way to "prioritize" thicker line weights when plotting, similar to how you can do so in AutoCAD. This is extremely problematic. For example, I always want cut walls line thickness (thickest line type) to show in front of all other elements, See image example:
Autodesk Customer Advisory Groups
