This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
"Max number of circuits" setting does not work for all panels (like data)
I have been in contact with Autodesk support about this.
In Revit 2020 we have an Electrical Equipment family which represents a Data-switch. This family is set to 'Part type' 'Other Panel'.
This family is loaded into a project. From this project through 'Edit Family' we change the 'Part type' to 'Switchboard'.
This adds several extra parameters to the family like 'Max #1 Pole breakers'.
We load this family into the project so the parameters are available in the project.
We change the 'Part Type' back to 'Other Panel' and reload the family into the project. This will keep the parameter 'Max #1 pole breakers'/'Max number of circuits':
This limits the number of data connection that can be made on the data switch.
This works fine for Revit 2020.
In Revit 2021 the 'Max #1 Pole Breakers' has been replaced by the 'Max number of circuits' parameter.
If we use the same methode with this parameter you can connect more than the set max number of circuits for the data switch:
Autodesk concluded with:
"There currently indeed is an inconsistency as "other" panels could not be limited using some kind of "Max number of ports" parameter.
As Data switches don't have breakers having the "Max #1 Pole breakers" parameter in a data switch is not supported in Revit. Using the hack that was working in 2020 was a really clever workaround (love it) but is currently not a design scenario in the current version."
Since we need to control the maximum number of connections to any panel i would like to suggest this to be implemented.
4 Comments
Arkadiusz_Lipski
Autodesk Support
Agree! There should be a way to limit the number of connections to any kind of panel, I believe we are a bit inconsistent here. I believe a "Maximum number of ports/connections" parameter would be great. Also what was discovered when reviewing this, is that when adding more 'systems' to an 'other' panel than the number of rows available in the schedule that no warning is provided.
jill_chen
Thanks for the feedback, does the "Max number of circuits" parameter needed for all the data panels as default parameters? so you may don't need the workaround (switch to Switchboard then Switch back to Other Panel) to get this parameter.
and Is the value of "Max number of circuits" for the data panel also matching the type(how many circuits could connect) of the physical data panel?
Thanks again!
Status changed to: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
The Factory
Implemented
We are pleased to say that this has been implemented in Revit 2025! Thank you for your contribution to improving Revit!
Help | MEP Parameters | Autodesk
 -The Factory
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
