"Hide Unchecked" for selected views/sheets to print
View/Sheet Set Needs a "Hide Unchecked" so you can see what sheets you actually have selected rather than having to sort through everything in the project. Other ideas have been suggested for printing from a schedule, which is fine if you only do sheets or a type of view. But if you're going to group things and sometimes print sheets and views together, then you need this.
1 Comment
kimberly.fuhrman
We are pleased to say that this has been implemented in Revit 2023! Thank you for your contribution to improving Revit!
Help | Work with View/Sheet Sets for Export | Autodesk
 -The Factory
