cancelar
Mostrando los resultados de
Quiere decir:
QR Code for BIM Model
Is there any possibility to create QR code for BIM Model?
4 Comentarios
Simon_Weel
And what should the code contain? Where do you want to place it? How do you expect to use it?
MOR-ConorMacken
Maybe an annotation type object that could be placed on a sheet or view which has a URL or other text property and then Revit encodes that URL/text as the QR code.
Then scan the code from a printed sheet with a phone and it brings you to the same sheet on the project's CDE?
karthikeyan.m3
@Simon_Weel actually code need to carry 3D model which need to place in Construction Site.
Answer: -
I got the answer from Fuzor and Autodesk Support Team.
karthikeyan.m3
@MOR-ConorMacken
Requirement.
            1. To Generate QR-Codes for BIM Model using Autodesk Application like Revit or Navisworks?
      2. A person working at the site can be able to view the models by scanning those QR-Codes placed at the site using Mobile.
Enviar idea
