In many real-world refurbishment projects, when a door is removed from an existing wall, the resulting opening is often retained—or filled in a way that differs from the original wall construction. In Revit, however, demolishing an existing door automatically triggers an “infill” behavior that closes up the opening with the original wall type. This is both unrealistic and irreversible, forcing users to accept an unwanted wall patch.
In actual practice, once a door is removed, the opening may remain as-is, be filled with a different wall type, or be repurposed in other ways. Having Revit automatically restore the original wall type is counterproductive and does not reflect typical site operations. It also removes the ability to keep a true opening without cumbersome workarounds.
Proposed Solution
User-Controlled Infill Settings
Flexible Phase Behavior
Better Alignment with Real-World Workflows
By introducing a user-defined or project-wide “Preserve Opening” setting, Revit’s demolition workflow would become more flexible and realistic, significantly improving modeling efficiency for renovation and refurbishment projects.
