Promille in Spot Slopes
In some countries (like Denmark), promille is often used in architectural projects to define slopes on flat roofs and bathroom floors etc., so it is a limitation that Revit is not supporting the promille indication.
It would be great if AutoDesk would enable the support of using promille in slopes and spot slope tags, in order to use the local standard were ever the project is being build.
3 Comments
KristianKvistgaard
Magnus.B
We have the same issue in MEP. I can get the slope in promille, ("per mille"?, not sure about the English term) but on a spot slope tag it's impossible.
I can annotate in per mille in a pipe tag but not on a spot slopeI can annotate in per mille in a pipe tag but not on a spot slope
dave_fagerstrom
This is resolved in Revit 2021.1.  Per Mille was added as a unit.
