It would be nice to have an option that can be turned on/off that allows for the Project Browser and Properties palettes to 'automate' when they are docked with tabs.
When those two palettes are tabbed, I'd like the properties palette to come to the front automatically when I select any object. It doesn't need to switch back to the project browser. Only needs to come to the front if it isn't already when an object is selected. Most times, if you select an object you will need the properties palette and NOT need the project browser. Not all users would find this helpful, or might only want it to function this way some of the time, hence I'd like to see it as an option that can be toggled on/off in the Options -> User Interface dialog.
