cancelar
Mostrando los resultados de
Quiere decir:
PROBLEMS WITH TEXT
PROBLEMS WITH TEXT
What happened to the text properties?? I used to be able to use shortcuts (IE: Cntrl+U = Underline, Cntrl+B = Bold). Why would you take them out for 2017?? It makes no sense to remove them. It is so much faster to use shortcuts rather than trying to find them on the ribbon! PLEASE return them!!!
5 Comentarios
treyk
 Hi Curtis--
I'm unable to reproduce your issue with the Ctrl+ shortcuts.  I've tried it on Windows 7, 8.1, and 10, and in all cases the shortcuts work:
1. Select a text note and click inside it to enter the text editor.
2. Highlight some of all of the text in the note.
3. Hit Ctrl+U on the keyboard... and all the selected text gets underlined.  Also works for Ctrl+B and Ctrl+I.
These shortcuts are out-of-the-box defaults in the Keyboard Shortcuts list.  Maybe you're using a custom Keyboard Shortcut list that has these removed for some reason?  If this is the case, they are easy to put back in:
1. Type KS to open the Keyboard Shortcuts dialog.
2. In the Search field, type "underline"
3. Select the Underline command (it should be the only one there).
4. Click in the Press new keys field.
5. Hit the Ctrl key and hit U.
6. Click on the Assign button.
7. OK
8. Your shortcut has returned!  Repeat the similar steps for Bold (Ctrl+B) and Italic (Ctrl+I).
Please let me know if you're still having problems with this!
Trey
sasha.crotty
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
sasha.crotty
El estado se ha cambiado a: Archived
sasha.crotty
sasha.crotty
Enviar idea
