cancelar
Mostrando los resultados de
Quiere decir:
Problem of corner wall join
Revit always gives hard time dealing with corner joint. But it gets worse by 2019, even with same height same level there's a big chance that two walls won't joint properly at corner. I tried all the method and tricks that used to work with the earlier versions but ends with nothing.
Please fix this issue with 2019!!!
1 Comentario
GA-LT
…"But it gets worse by 2019" …. ha ha ha. In my opinion it could not be worse so please fix it and give us clear working rules of joining walls in corners, sections and with beams, slabs, floors etc.  Adding nice clear priority parameter to walls layers it can be more automatic and save a lot of time !!
Enviar idea
