Print window
Print window
I'm sure someone must have already submitted this but I could not find it.
I'm not a fan of the print "visible portion of current window" option. I'd love a print window similar to Autocad.
There's too much back and forth between the print dialog and the view window to get the desired area to print.
47 Comments
PLColombo
I am married to a programmer, so I understand your point about them not being the same code. However, it is important to note that the AutoCAD version of print window works well whereas the Revit version is not equivalent. It is awkward, clumsy, are requires trial and error. The people who design the software are not the people that use the software. It appears they have no clue why we would only want to print ONLY a small portion of a sheet with out extra parts hanging out along the edges.
RichConyers
@dplumb_BWBR, I understand that the programs were build on two separate coding platforms. My statement was not about copying the code, it was an illustration that a printing feature in Autocad developed LONG ago has not made its way to Revit even with significant requests from users. This is not modeling issues or carrying shared parametric information level stuff. Printing specific information in a view is a fairly simple solution, and as I remarked previously, one they have figured out in a parallel program previously. Your analogy would be closer to comparing a quad transmission to a motorcycle (which is much closer that a minivan)  :).
As in autocad, adding the window option under the what to plot menu on the print screen will be a great convenience.
Tags (4)
A search prior to posting would have been a good idea....
https://forums.autodesk.com/t5/revit-ideas/print-window/idi-p/6473348?advanced=false&collapse_discus...
Personally...while the print by window does exist (but is a pain in the....) I like to use the snipping tool in Windows and grab a screenshot and print that.
rasmus.oberg
Implementing this would be appreciated by a lot of people, it's a very common part of a normal workflow.
MOR-ConorMacken
The "visible portion of current window" option is the solution to a problem that simply doesn't exist.
lonerganjeff
It does not work well at all.
Example. I want to print what is shown in the window.
[image: image.png]
Preview of what it actually wants to print.
[image: image.png]
Window selection like a lot of other software would solve this.
Forma Design Contest
