La sugerencia automática le ayuda a obtener, de forma rápida, resultados precisos de su búsqueda al sugerirle posibles coincidencias mientras escribe.
Mostrando los resultados de
Mostrar solo
Buscar en lugar de
Quiere decir:
Esta página se tradujo para tu conveniencia mediante un servicio de traducción automática. No es una traducción oficial, y puede contener errores o traducciones imprecisas. Autodesk no garantiza, ni expresa ni implícitamente, la precisión, la confiabilidad ni la exhaustividad de la información traducida por el servicio de traducción automática y no será responsable por los daños o las pérdidas que se produzcan como consecuencia de la confianza depositada en dicho servicio.Traducir
How about not even going to the Project Browser - would that work for you?
If so, Ctrl+P is the answer - or the Revit Application Button.
Either way, you can then Select (3) Print Range from the Print Dialog, then choose the sheet, sheets and/or views you want to print, and if necessary save the print set for later use.
Or, do you want to be able to right click on sheet(s) in the PB and select print?
What Whitbrs suggests is what I would like to do, (Second option, ctl select sheets, rightclick print those sheets) am I missing some basic knowhow, the image you posted is bang on how I see it working, but my Revit doesn't give that option. Is there an extension I'm missing?
@RolyNZ The first option that @whitbrs described is the OOTB behavior that's already available. The second option is just a graphical creation of the actual wish that you posted.
@lionel.kai Thanks, I thought I was missing some functionality. OOTB option is pretty click heavy IMO the second option, although not pretty, seems pretty obvious to me. Select drawings, right click print...
Something that would enable faster printing would be to store the (default/full-size) setup for the Sheet (similar to how AutoCAD does) without having to select it every time you re-open the model.
@RolyNZI was about to post this exact idea, apparently 4 years late. I tried to search for the idea via the Search Suggestions but only recently saw your post. The Revit brass really need to put their heads together on this one. It's a button. @whitbrs your response is EXACTLY what we are looking for.
Print sheet collections from the browser by right clicking on the heading of the sheet collection
Export directly from the browser as well, just as important as I can't count the amount of times I get cad file requests.
So I think we could all agree that we can see the sheets we want to print but it feels like we have to go through a small government to get them printed or exported.
