Print Settings - Combine multiple selected views/sheets into a single file
Currently, when printing in Revit, the 'File Settings' default to "Combine multiple selected views/sheets into a single file." - which is perfect - as discussed previously in the forums here:
https://forums.autodesk.com/t5/revit-ideas/print-default-should-be-quot-combine-shhets-into-single-f...
BeforeBefore
Unfortunately, after selecting different 'Printer Names', views in the 'Print Range', or 'Print Settings', the 'File Settings' switch to "Create separate files."
AfterAfter
This should not happen. Print settings should not change when going from one menu setting to another. Print settings should remain as selected unless manually changed by the user. As noted by @lionel.kai. Please fix. It's really annoying - especially when I'm in a hurry and forget before printing a 100 page document.
11 Comments
kimberly.fuhrman
Hi, @chris.jones9VA3R ,
Here is a similar Idea...should I combine this one with yours?
PDF Printing - Combine Multiple problem - Autodesk Community
Thank you for your submission!
Kimberly
chris.jones9VA3R
Hi Kimberly,
It's not clear to me he is referring to the same issue, but I can't quite tell. I feel like it is the same issue, but the way he words it makes me think it's not - so, I don't know. Sorry I guess that's not very helpful.
Chris
kimberly.fuhrman
@chris.jones9VA3R  I can keep them as separate Ideas for now and will monitor both for activity.
Thanks again!
Kimberly
a.wilsonXT342
Bumping this.
I appreciate that there's now a warning popup now which says are you sure you want to create separate files because it has saved me from accidentally creating  40 pdf's.  However, a warning popup being necessary for a default setting on a routine task seems to be an indication that the wrong default is being used.
Having it stay with last used or combined seems to be a better solution; as well as not changing when other properties of the print job are altered - that is confusing / annoying.
tlagardeAJBTA
Indeed, they thought they had fixed the problem but they didn't troubleshot it. Classic, I am upvoting your idea
tlagardeAJBTA
Any traction on really implementing this in Revit by default ? @Anonymous @help @kimberly.fuhrman ?
This behavior by default needs to change across the board, not just in one condition, please refer yourself to this all thread for details.
tlagardeAJBTA
No answer from anybody regarding a setting that has been needed by the community for ages now ?
We have to change this thing everytime we need to print, it's ridiculous.
kimberly.fuhrman
Hi, @tlagardeAJBTA !
I feel your pain on this one! I'm going to file this one as a problem report. Thank you all for bringing it back to life.
tlagardeAJBTA
Sure, do you mean that this will be fixed in the next releases ? This would be great, thank you
chris.jones9VA3R
@tlagardeAJBTA- It would be pretty great. At this point it's just a part of my routine every time I print to check this setting. Would be nice to not have to do that anymore.
tlagardeAJBTA
We shouldn't get used to bad setups.
