La sugerencia automática le ayuda a obtener, de forma rápida, resultados precisos de su búsqueda al sugerirle posibles coincidencias mientras escribe.
Mostrando los resultados de
Mostrar solo
Buscar en lugar de
Quiere decir:
Esta página se tradujo para tu conveniencia mediante un servicio de traducción automática. No es una traducción oficial, y puede contener errores o traducciones imprecisas. Autodesk no garantiza, ni expresa ni implícitamente, la precisión, la confiabilidad ni la exhaustividad de la información traducida por el servicio de traducción automática y no será responsable por los daños o las pérdidas que se produzcan como consecuencia de la confianza depositada en dicho servicio.Traducir
I assume that you're talking about xclips for NESTED cad links, since you can't save an "xclip" boundary in the drawing (to be used when it gets linked in by another)?
I'd like to see that taken a step further: having it default to the current xclip would be fine, but I'd like to have control over the crop independently of the view's main Crop Region (and actually for the main/parent cad file, not just nested links).
I just had this issue and support suggested I vote for this. My problem was importing an xclip dwg into revit (Revit does not recognize clips.)
My workaround with 2017 was to publish as a pdf then use the importpdf to bring it back in. This way you get all your colors and layers. While it does introduce a small error it's better than having to manually clip all those reference drawings (100's) every time the architect sends us an update.
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
