cancelar
Mostrando los resultados de
Quiere decir:
plausible parametric angular capability within families
Currently it is near impossible to simply make a parametric angular control for geometry that is not so fragile that the family breaks when flexed. Maybe what is needed is a point entity that can be pinned so a nested family can be pinned to and rotated around it, and an angular dimension that knows that -20 degrees is not the same as 110 degrees. Whatever, can we please have some support to plausibly drive things with angular parameters.
3 Comentarios
Scott_D_
I support this.
Building rotation into a family is unnecessarily difficult.
Trying to built rotation and tilt into a family at the same time is essentially impossible.
Can I vote for this about 20 times?
ksmithBMBHQ
I've really been struggling with this for a few hours. If only there was a way to pin the end point of a reference line / plane so that it would work as a sort of "hinge" around which angular dimensions will always rotate.
jjenkins4
Yeah! That would do it!
Enviar idea
