Placing fabric area/fabric sheet in curved walls
Right now there is no way to place fabric area or fabric sheets in a curved wall, only possible in straight walls.
It would be nice if this would be possible in the future releases of Revit.
6 Comments
teodorb
Status changed to: Gathering Support
Hi @Anonymous ,
You have the ability to use the Sketch option for fabrics in order to obtain curved fabric. Here is the link from the help:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/Revit-Model/files/GUID-098B9B94-B06D-4455-BDA6-182AB2E1ECEA-htm.html
Could you also provide more input on what are your expectations on this request, because you are speaking about both fabric and fabric area.
Kind regards,
Hi @teodorb ,
The skeetch option for fabrics works well for straight walls because that's a valid host.
Once I draw a curved wall like this picture:
This curved wall cannot host a fabric sheet or a fabric area. It would be nice if both fabric area and fabric sheets are possible.
teodorb
Hi @Anonymous ,
Below is the screencast showing how you could add bent fabric sheet to a curved wall:
https://autode.sk/2RboWmM
In order to add the bent fabric sheet, you have to have no element selected.
Let me know if you need additional information.
Kind regards,
Hi @teodorb ,
Thank you for the screencast of the fabric sheet.
Is it also possible to place fabric area to a curved wall as well?
teodorb
Hi @Anonymous ,
The fabric area is bound to a plane. It cannot populate a surface (in your case a circular surface). This post should be addressing to this issue. Fabric area in curved walls.
Hi @teodorb ,
Yes, that's correct. It should be placing fabric area in curved walls.
Autodesk Customer Advisory Groups
