Pipe and Conduits longitudinal bending
I wish that Revit could Create a pipes with slight longitudinal bending As Shown In Sketch
without the need of fittings
to make an option in pipe segments that allow this kind of bending which add another column to set Min radius (maximum bending) to each size which is sometimes given by some manufacturers.
this will help creating pipes aligning with rotating paths with very big radius which sometimes in reality needs to give pipes a slight bend.
this can be also Applied on Conduits 🙂
note that this will need to consider the relation between bent pipes and pipe fittings
Forma Design Contest
Technology Administrators
