La sugerencia automática le ayuda a obtener, de forma rápida, resultados precisos de su búsqueda al sugerirle posibles coincidencias mientras escribe.
Mostrando los resultados de
Mostrar solo
Buscar en lugar de
Quiere decir:
Esta página se tradujo para tu conveniencia mediante un servicio de traducción automática. No es una traducción oficial, y puede contener errores o traducciones imprecisas. Autodesk no garantiza, ni expresa ni implícitamente, la precisión, la confiabilidad ni la exhaustividad de la información traducida por el servicio de traducción automática y no será responsable por los daños o las pérdidas que se produzcan como consecuencia de la confianza depositada en dicho servicio.Traducir
Enviado porAnonymousel05-13-201609:21 AM
Estado:
Archived
Phase Parameter Tag
I would like to be able to add the Phase of an element into the tag. For Example: EXIST W8X10, DEMO W8X10, TEMP W8X10 etc... Being able to change the Phase Name Existing to EXIST would be nice too.
What if you used a calculation in the tag? don't know if that is possible but maybe in 2017. And Demo shouldn't be a phase, and probably not temp either. Because most elements have a "created" selection and a "demolished" selection. Meaning temp = created and demolished in the same phase. Demo is depedent on your perspective. If the element is in Existing and demolished in New Construction, when the view is Existing, it isn't demo'd. In New Construction it is.
The Temp and Demo phase are fine and should be kept. I use them all the time. Temp phase to show that things like scaffolding are to be put up and torn down during construction. Demo phase should be dependent on your time/phase perspective. If I demo something in new construction it doesn't mean it was demoed in existing? It also means that that it will not show up in any phase after new.
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
