Performance improvement while creating Section Views on big models
While working on big models it's common to have some performance reduction while drawing a Section line.
It would be useful to, first of all, the user draws the section line as a 2D simple line, without processing. After finishing the placement of the line, Revit will start processing the section view it.
In my case, I'm working right now on a model that the easiest way to create a section view is to duplicate another and move it to the desired place. Sometimes when I start drawing the section line Revit goes slow after the click on first selected point.
3 Comments
Karol_Piroska
another workaround is to disable association between section and view template. Apply the view template manually after you create a section.
magno.vinicius.silva
@Karol_Piroska thanks for your feedback.
It really works and improve the performance, but it's still slow on heavy models.
cprettyman
This would be huge - right now, on some larger projects, we have to close several worksets (including most of the linked background models for other disciplines), to create sections - if we do not, creating a section goes into a "generating graphics" loop that seems to restart every time the cursor is moved -
