Parameters can take two values at the same time
I wanted to create a field in the sheet layouts to color the plans per disciplin. I assigned an integer to use the input to control the yes/no parameters. I wanted the same integer to appear in the sheet layout as well since it is part of the plan code, after loading the sheet layout in the project I assigned the integer as a project parameter of the sheets. the idea was to input this integer parameter in the plan list and accordingly have every sheet take a different color when created for easier sorting. Turn out that the same parameter can be assigned a value in the sheet properties and another value in layout properties.
Although this paramters is a common used parameter, if it is used as a family parameter (sheet layout in this case), it loses its property to be a common used parameter and becomes only a family parameter.
Any solution around this? I can send the file and creat screenshots if needed
PS: creating global paramter and setting both equal to it does not help in this case.
2 Comments
szilagyi.balazs
Assign the same Shared Parameter to the project and the sheet family. (https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...)
Status changed to: Archived
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community (votes or comments) over the last 24 months and as such we will not be pursuing it at this time. Please feel free to re-word (titles and clear descriptions are very important) and resubmit this Idea.
