Override Shortcut
Override Shortcut
Very often throughout a project, I am using the override graphics tab to change the projection lines of detail items. And usually, it is to the same settings. In my case it is a certain shade of gray, and line weight 3. That being said, it would be far more convenient and save a lot of time if I could make a keyboard shortcut specifically for a preset graphic override, avoiding the busy work of opening the tab and selecting the same overside settings over and over and over within multiple sections. Just doubletap XX for example.
2 Comments
Hi, @PMaillefer ,
Is this something that a View Template could assist with? Rather than selecting individual lines, create a subcategory under Detail Items in the Object Styles and apply overrides that way.
samuelsanf
@PMaillefer you can go to Manage -> Aditional Settings -> Line Styles
And add an new type of line with the color and lineweight you want to use in views by simply selecting this line type in Detail Line, and draw it.
