It will be great if we can have an option to change the detail level of particular elements in a view. It will give us more control to show some of the elements as want to see in the views without changing the detail level of the whole view. It will eliminate some of the part plan/detail view for some of the areas and save us some time.
It will be ideal for piping drawings; in which we can set up the detail level as "Fine" for vertical pipes/risers, so it will show the actual space taken by the pipe in the shaft, and the detail level for all other piping on a plan can be set as "Medium", so all other piping will show up as single line in the view, hence it will eliminate the requirement of showing separate shaft detail on a separate view.
