Overlapping Rebar
Overlapping Rebar
Hello everyone. In Revit would be perfect to add:
1) overlapping for rebar
2) Different distance between rebars
6 Comments
YarUnderoaker
I think this must be rebar set upgrade which added some new instance parameters.
Overlapping must be optional.
Scheduling will be like for varying rebar set and counting full length rebar and additional rebar.
This will be work with straight rebar with/without hooks.
ipselute
Overlapping with optional cranking would be even better. Simple overlapping might turn into a nightmare in beams or columns with lots of rebars. Sometimes, bar-end cranking saves the day.
YarUnderoaker
 Please, can you post image where is overlapping with cranking. I just do not know such a term.
ipselute
@YarUnderoaker : Exactly like this: https://forums.autodesk.com/t5/revit-structure-forum/rebar-splice-crank/td-p/8259565 . Such option was available in Advance Concrete, i believe. Such option is available in Tekla for a very long time.
peticid
Status changed to: Accepted
We are pleased to say that this has been implemented in Revit 2026! Thank you for your contribution to improving Revit!
Help | Parametric Rebar Cranking | Autodesk
 -The Factory
