Options - Automatic Moving Elements into Option
After Creating an Option Set with both an 'original' and a 'new' option (naming not important, point is there would be 2 options in the set) having Revit Automatically select elements and 'move' them into the options as the elements in the main model are selected and modified (including dependent/related elements, such as hosted elements, rooms etc.) by putting one copy in its original state in the first option, and the modified element in the second. Might look a bit like the element displacement interface?  It would make using Options for quickly trying-out a design change much more friendly.  Currently, it requires too much pre-planning and thinking about which elements need to be copied/'moved' into the options, i.e. too much time 'overhead' which keeps it from being a go-to tool for quickly testing-out ideas.
