cancelar
Mostrando los resultados de
Quiere decir:
Option to link origin to survey point
Surveys and consultant base files are drawn from the origin of the DWG file. In Revit the project base point is set to be a point close to the project whereas the survey point is 0,0,0. When linking in a DWG where the 0,0,0 matches the location of the survey point in Revit it would be ideal to have an option to link the origin to survey point.
1 Comentario
samuelsanf
Revit "Survey Point" is not defined to be coordinates 0, 0, 0 always. But I agree that matching DWG coordinates with Survey Point (current value) would be usefull, even if there is not coordinate system defined.
Enviar idea
