cancelar
Mostrando los resultados de
Quiere decir:
Offset an attached wall
 When a wall is attached to a, for example, sloped roof, there should be a possibility to give the wall a top offset. So that there is space created for a wall plate of some other construction.
2 Comentarios
lautarolzl
Have you found a way after all this time? I got here with the same question.
No aplicable
@lautarolzl  + @Anonymous   A couple years out, so unsure if either of you have found a solution to this yet, but having just come into a similar issue with a project I'm working on now, a coworker of mine told me the best way to perform this offset would be to draw a reference plane parallel to your slope, then offset the reference plane your desired amount (you can then create a parameter for the offset to be changed later), then attach the wall(s) to the reference plane instead rather than the roof or ceiling.  Worked perfectly for some skylight bulkheads for me and was a good tip to come across in the office.
Enviar idea
