cancelar
Mostrando los resultados de
Quiere decir:
Non Printable Text, Lines, Workset or Phase, markups, task list.
Can we have a non printable Text.
Many times we need a reference text to be available to explain something, or just to jot down your thought while working to come back to resolve it..
Some dialog or text box , or like a markup on all types of views which is not printable but purely for people working on the file.
This will help so much while collaborating as well as people wont forget pending things.
Most of the time the brilliant idea gets lost cause it was not written anywhere..
While doing this we can also have  a list of these "to do things" ,
where we can assign task to users and shortcut to go
to that particular location to work on..
I am know am asking too much, kind of combination of PDF markups, Internet hyperlinks, Microsoft office task list, Schedule and property
of AutoCAD Defpoint layer which doesn't get printed..
76 Comentarios
Shivaprasad.MN
In Revit, we don't have plot option for line style like auto CAD. If we introduce this option we can TURN OFF the layer that doesn't required while printing.
Example: Let say., we are working on floor framing plan / detail and have some queries on particular location (may be require some updates on connection / information from Engineer / Architect etc.,)., we wanted to highlight / mark  this location with RFI line style to come back later in future once the query is addressed / got an answer. some time will not receive an answer in time - let say at the time of 50% construction document submission, but we wanted to share the PDF set with another discipline / owner for their reference. At this time we cannot share the PDF set with RFI lines to the other disciplines / owner, forcefully we've to delete these RFI lines to share to generate PDF and huge chances of loosing the problematic location.
To solve this issue, we need to introduce an Plot option for line style., we can turn off this Particular line style in line style plot setting., Please consider this and if possible, please introduce this., this really helps a lot for many Revit users.
wr.marshall
You can create view templates and then a schedule to control which view template a view uses.
abbe_flores
A non-print text would be very helpful for making internal notes.
Shivaprasad.MN
Marshall, It's not about hiding the line type in the plan or detail., it's about the controlling the plot of particular line style without hiding it. Please read the Post in detail and then reply..
wr.marshall
I get your idea and think it's a good one so voted for it. Though not ideal to quickly get the right printing settings as per my suggestion is create templates and schedule to control which template a view uses, until such time as if and when Autodesk might implement this idea!!!
Shivaprasad.MN
Thank you Marshall...:cara_que_sonríe_con_ojos_sonrientes:
mlg3ga
Observer
This would be super helpful! Also need to track revisions clouds that do not print in the title block.
mwilson0927!
I'm often making personal notes on my plans for myself or my team but don't want them to print.
HVAC-Novice
It also would be good to have one global parameter or checkbox to turn them on/off for printing. My personal notes sometimes should be printed, sometimes not depending on the audience.
hplankFDYRF
AutoCAD has the non-plot option in layer properties and has defpoints. This would be extremely useful in Revit when work-sharing so notes may be left on sheets and views.
Maybe this could be done with a yes/no parameter named "Visible on print" or something.
wr.marshall
wr.marshall
Christiaan_de_Wit
Maybe you can use Revisions to accomplish what you want? For every Revision round, you can choose whether the cloud, tag, or both should be displayed.
t.slaughterBEV3P
Observer
Why not just a sticky note type tool. obvious note that can be moved around and added with different colored fonts ... even a checklist for accomplished tasks .
erin.card
Lots of submitted iteration/variation ideas on this -- hope to see some version of this for Revit '24!  Especially with an ever-more persistent work-from-home environment.
Excelente ideia! obrigado pelo envio @mwilson0927!
wr.marshall
Similar idea here
Notes for team members - Autodesk Community
If feel the same please ask @kimberly_fuhrman-jones to combine
skyeg321
There should be a way to toggle colored borders around these elements to communicate with team members the level of completion. For example does the roof plan sheet need work? Does the text in a legend need review? We are using a Bluebeam session for this communication but it could be built into projects and this would save us from exporting pdfs for bluebeam. It could be called team notes or something and be toggled on or off. This would effectively be a built in redline tool. Could really save time!
wr.marshall
Enviar idea
