need to add the ability to autosize columns and rows based on length/height of field text
in Excel, you click on the triangle upper left and double tap a column or row edge to austosize all columns/rows based on the longest/tallest field text. There needs to be a way to do this in revit schedules. It's time consuming and tedious to have to do this manually on every schedule on every spool sheet in a multistory project.
1 Comment
fruity101079
Not only in schedules but everywhere.
In Links, you can't see the full folder of a linked rvt file and double click reduce the column instead of expanding it!
