Multi user access on working with revisions in worksharing files
On behalf of a customer from Germany let me post the following wish: Make more flexible the work with revisions in worksharing files and this way allowing that multiple use can work on revisions at the same time.
Currently only one person can works on revisions and the next one have to wait until the model is synced.
3 Comments
Stefan_Wolf_WST
I fully aggree to this wish... but for us it is more something really necessary!
As we are working in big teams on big projects, but only one is able to make changes to the Revisiontable... costs lot of time only for waiting to ask a collegue to synchronize and then synchonize my model to be able to make changes.
From my point of view - making the decision to make sheet-Revision by project or sheet is like, working with worksharing or not. You can not switch between worksharing and a stand alone model...
When I make the decision for sheets, it should be easy to handle one revision schedule per sheet... as we desided...
maybe you will not believe, but we loose hundrets of hours only for synchronizing to organize sheet-management in big projects.
Everybody of the product design is highly wellcome to work with us to see this painfull issue.
peter_szakal
Community Visitor
I totally agree: it's a common problem in both ACC and REVIT within a company. If the model contains plan sheets for several floors and several technical areas, no matter how much manpower you have, you cannot edit plans simultaneously that are completely separate in terms of content and representation. Teamwork through a virtual "serial port": a complete waste of time...
There can hardly be anything more frustrating during deadlines.
Aku-J
This would be a great addition!
At the very least, I would appreciate a warning message indicating that the Revisions workset has changed, or that someone else is modifying it, so I know to sync before making edits. Nothing is more frustrating than spending a long time typing revisions, only to be greeted with the flollowing error when you press OK, thinking you’re finished.
This would likely require some kind of "Edit" or "Make Editable" button, but I would still prefer that over the all-too-common scenario described above—especially on big submission days, which are already hectic.
Ideally, each revision could be borrowed separately, like any other element. That would be the best solution from a user perspective, though I understand it might be more complex to implement."
