Multi Span Beam Reinforcement using Naviate Extension
When Reinforcing a multi-span beam using Naviate Reinforcement Extension, the only way for the extension to recognize it is a multi span beam is to draw the beam in on run over all of it's supports which is not good when taking the model to a structural analysis program.
Also, when making a joist system, the extension does not recognize the girder as a support for a multi-span rib even if it was drawn in one run.
Autodesk Customer Advisory Groups
