Harder to put into words than show an image, but I would like to be able to tag Walls, Roofs, Floors with an assembly tag that has a schedule of the item's structure
attached is an image of the annotative symbol we use to ensure assembly callouts are consistant,
The Idea would be in a Multi-Category tag that you can create a schedule inside the tag in which you could pull any column of the structure parameter properties in as a row. (We would use Material, Thickness)
We would have a second "header" label which would pull "Description" from Identity Data
You could then compose an assembly tag that looked something like
<Description>
"Structure"
- <Thickness Row 1> <Material Row 1>
- <Thickness Row 2> <Material Row 2>
- <Thickness Row 3> <Material Row 3>
That would in project Yield:
Typical Interior Wall
Structure
- 5/8" Gypsum Wall Board
- 3 5/8" Metal - Stud
