I've browsed existing posts as I'm sure this must have been posted before but couldn't find anything.
{apologies in advance if this feature exists - I'm using Revit LT 2021}
The existing feature allowing the control of specified wall layers to be extended above or below the other layers of the wall is great: I always aim to build models as close as possible to the real world. It also saves time and hassle when creating sections and details.
However, at the moment only adjacent layers can be contolled in this way. In the real world external finishes, insulation, internal finishes, the inner leaf of a cavity wall and so on, often extend above or below other elements of the walls make up.
It would great if each layer could be controlled individually. Even better: make this the default setting for all layers.
