Often there are existing CAD, object, or linked file that needs to be followed when modifying floor sub elements. my work around has been to DRAW lines first then use modify sub element feature to snap to those lines. but Enough is Enough! please let us snap to lines and edges and corners when using "add point" or "add split line" or "Pick Supports" when using the "modify sub elements" feature.
Thank you!
