Modify Room Base Level
Whenever we need to correct the base limit of a room, we have to delete and create it at the correct level!
The "Level" parameter in the image below should not be locked by Revit, so we could make this change more easily.Room Level.JPG
4 Comments
nick-tanner
Yes! This is an important item to have so that the room doesn't have to be deleted, and re-inserted.
aricke59
If this is an immediate concern for you it is worth knowing that ARUtils has a routine to handle this situation - obviously not as good as having the ability built in to Revit.
Having created rooms on the wrong level the effort required to shift them to the intended level is time consuming. The routine also allows you do delete a level and have rooms (and any level dependent items) moved to a specified level.
Note: I am the developer.
andybonesz
This would be a great feature, and seems like it would be a high priority, but given the fact that this thread is 3 years old I guess not.
MiWolff
Given that the OP is now Anonymous is also a hint to the importance of this bug fix idea.
