Model instanced cut pattern for walls
Make the cut pattern for walls model based.
A big bottle neck in Revit is that cut pattern is a drafting type and not a model one. When modelling a wall in revit the cut pattern from the section is flawed. One has to find a pat file that fits then try to rescale it just to finally come to realise that it was a waste of time since it dosent scale with views and  cannot be placed where desired in the pattern. This leads to that one has to compensate every wall section/detail with manually draw insulation details in 2D while working on a 3D program. Having to explain this to my boss or buyers of projects that a famous 3D program is so flawed that a slight change in a wall placement leads to hours of work and risk of printing flawed plans/details when one expect it begin smooth and easy. Apperently other programs can handle these.
Sincerely
Rob
