cancelar
Mostrando los resultados de
Quiere decir:
Mid Of Two Points Snap
Add a new snap the same as AutoCAD's 'Mid of two points'.
31 Comentarios
ckingACC2T
Observer
This would save millions of clicks when centering items in grid ceilings.
Hugh_Compton
@sashacrotty Please overhaul the snaps system in Revit.  Blender Snaps totally embarrass Revit.
El estado se ha cambiado a: Gathering Support
To reorganize and consolidate our Revit Ideas for ease of use to both our customers and our product teams, we are no longer using the "Future Consideration" status for Revit Ideas. All Revit Ideas are always under review, and consolidating posts (and Kudos!) will give weight to topics previously spread across many posts. We are continuing to evaluate where this request falls into our roadmap and will provide an update when we have made a decision.
Thank you for your contribution!
-The Factory
El estado se ha cambiado a: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
The Factory
El estado se ha cambiado a: Implemented
We are pleased to say that this has been implemented in Revit 2022.1. Thank you for contributing to the improvement of Revit!
-The Factory
sash.kazeminejad
Just tried it out and it is only half as good as I had hoped. While it works well for placing certain components between two references, it does not work at all when trying to place, say, a window or a door centered between two elements. The example I tested was placing a couple of elements along a wall and then trying to center a window between those elements using the (S2) snap feature. Revit will not allow that. You can place other non-hosted components using the (S2) snap feature but it appears to not work with wall hosted elements. I have not tested this with other components but I suspect the results will be the same. Hopefully this will be enhanced in the next version of Revit.
Tarek_K
Tarek_K
Tommy_S
Just discovered that my favorite acad snap finally has been implemented in revit, nice!
k.sharif
Community Visitor
Snap Mid-Point Between Two Points'
Etiquetas (1)
Hi, @k.sharif ,
This functionality was implemented in Revit 2022.1. I will combine your post with the original Idea.
Thank you!
Kimberly
Enviar idea
