As a Latina architect, I have used the metric system for years before I moved to the United States. The wrong use of the metric system have caused million dollar mistakes to this country in the past, for example the loss of a spacecraft. I do not think NASA uses the millimeter as a base unit for measurement!
Why do you recommend the use of the millimeter in the metric system as the base unit for engineering and architectural drawings? I am astonished when I see how bad the system is used and when I listened seminars, watch tutorials, and read your books using mistakenly the millimeter.
The millimeter is used in exceptions such drawing 1:1 scale for example to draw a nut or a bolt. I am sure that this situation is causing confusion but probably it is not too late to change the metric system using the meter as the base unit. A door, for example, is not 800 millimeters but it is 80 centimeters or .80 meters. After one meter, the centimeters is not the base unit anymore and the meter becomes the base unit, for example, 1.50 meters or 325. 80 meters.
I used in South America the comma for decimals and period for thousand and million. Besides we work clockwise as positive input and counterclockwise as the negative input, but if we have to use wrongly the metric system, the situation becomes very confusing. An urban plan supposed to be in millimeters also? Even a building will have millions of millimeters? In these cases the results will be astronomic. Every time that I notice the mistake, I feel discourage because your important company is the forerunner in drafting software and you are leading this ugly mistake recommending it to people involved in the use of your multiple software.
I have used for years AutoCAD, Architectural Desktop, 3D Studio Max, Revit, and other software using the imperial system but when I see the use of these software in the metric system, the use is WRONG! I hope my comment would be useful. Thank you for your time.
