cancelar
Mostrando los resultados de
Quiere decir:
MEP - Auto Circuit/Wiring to Generate Layouts
It would be great if Autodesk could implement Arc or Chamfered "Wiring Options" to have a "Generate Layout" option similar to the Mechanical or Piping "Generate Layout" option. Then you can cycle through a couple of auto wiring options and select a preferred route or direction of wiring/circuiting.
A few things which you could do at this stage is:
  • Connect Power to the desired elements, then draw the Wires in manually by means of using Arc, Chamfered or Spline wires.
  • Connect Power , then automatically connect, then use the Vertex to move the wire to the desired direction.
  • Connect Power , then automatically connect, then only delete the wires which you would like to change the direction to, then draw your desired wires with the desired directions in manually.
  • Connect Power, use Arc wires, then in the Properties Palette, change the wires from Arc to Chamfered. (Or vice versa).
  • You could also apply WIRE FILTERS to each wire to at least get the wires to appear different.
Above is just a rundown of possible wiring options which is possible at this stage.
It would be great to have Auto Wiring/Circuiting options where we could also use a generate a layout in order for us to select a preferred route or direction of auto wires.
1 Comentario
gianfranco_pavan
Important function. Electrical engineers need it.
Enviar idea
