La sugerencia automática le ayuda a obtener, de forma rápida, resultados precisos de su búsqueda al sugerirle posibles coincidencias mientras escribe.
Mostrando los resultados de
Mostrar solo
Buscar en lugar de
Quiere decir:
Esta página se tradujo para tu conveniencia mediante un servicio de traducción automática. No es una traducción oficial, y puede contener errores o traducciones imprecisas. Autodesk no garantiza, ni expresa ni implícitamente, la precisión, la confiabilidad ni la exhaustividad de la información traducida por el servicio de traducción automática y no será responsable por los daños o las pérdidas que se produzcan como consecuencia de la confianza depositada en dicho servicio.Traducir
Now its 2021 and measure tool in 3D is still nowhere to be found? I'm sure Autodesk and the Revit dev team has a lot on their plates - but just wanted to check in and let you know that users still wants this feature
This seems to be such a basic thing-why can't you sort it Autodesk? The only solution seems to be to buy a plug in. If I did that every time I wanted a basic thing I would spend double on Revit that we already do. At nearly £3K a year it is cripplingly expensive as it is..
Give us "measure in 3d" please! It should be as simple as pressing one key.
When I started using Revit the lack of this feature just blew my mind. I still can't wrap my head around that Autodesk built a 3D collaborative modelling environment without giving users the ability to check the relative position of objects in 3D space at a glance. I mean, Revit must know where the objects are already, right?
This functionality is super useful, not just for fluffy conceptual design modelling, but also for checking the location of 3D models from consultants which otherwise are more time consuming to get to display correctly in plan or section views.
