Marquee Tool
Marquee Tool
A Marquee tool similar to ArchiCAD. User is able to draw a marquee around a space in plan. When 3D mode is activated, only things within the marquee show in 3D. Much easier than adjusting the section box each time you want to view a small area of the overall model in 3D.
2 Comments
So while this is not a "marquee"...Xrev has a Freebie Add-in that does similar but everything that is selected will be isolated in 3D. https://apps.autodesk.com/RVT/en/Detail/Index?id=5513670845846828779&appLang=en&os=Win64
The creator of the add-in used to use ArchiCAD too...
flopezEseMero
Como usuario de ambos programas, es una herramienta que uso mucho en ArchiCAD y que deseo siempre en Revit que siempre he necesitado
