I would like to select (using the Tab key) a single property line segment on a model view in Revit, for naming it or change it mark value.
In order to mark property line segments on Revit, we have to create a schedule, and in the schedule select each one comparing their parameters and then naming each one. This is simple on a project with a few property line segments, but that isn't allways the case.
I usually open the property line segment and select every instance, once at time, click "Highlight in Model", to know which segment is and then mark it name. This is the most efficient way I found, but it isn't enough efficient.
