Make Tread Numbers work with Multistory Stairs
Tread Numbers don't work properly with Multistory stairs.
They should.
Create multistory stairs using the 'Multistory Top Level' stair parameters
Tread numbers can only be applied to the bottom stair flight
Upper levels above won't number.
This is inconsistent and forces the user to add manual text.
1 Comment
@Kevin.Bell , it looks like this was implemented in Revit 2018 per this Idea! My apologies for the oversight in marking your Idea as implemented, too! Thank you for your contributions to Revit Ideas!
